68 5000 8 speed neutral switch and manuals
Alan8n
Just discovered my NEW 5000 safety switch has been jumped out. The service manuals imply that it should be an easy fix. It looks like I just need to pull the cover and swap switches. Anything I'm missing ?
I did invest in the complete set of service manuals but they leave me a bit confused. In some places they do say specifically for the "5000" in a lot of places, in particular, the transmission section, they have a section specifically for the Super Major 5000, but nothing specifically for the "5000" That is the case in other places as well. They have specific sections for Dexta's and Majors and Super Majors, but I rarely see a section specifically for "5000". Question is is the "Super Major 5000" the same as "5000". Is the information in the "Super Major 5000" sections the same for a "5000"?
Thanks
Alan
Have you tested the switch with an ohm meter? I asked because mine was bypassed on my 4000 for no reason. Someone here suggested testing it before I tore into it and it was fine. I wired it back in and has worked perfect since.
