901 power steering parts
Greg NE
Location
Duncan, Nebraska
I have a 59 971 that I'm trying to
resurrect the power steering on. I'm trying
to find a seal kit or the individual seals
for the control valve that aren't quite as
gold plated as what New Holland wants for
them. I'm not having much luck finding them
anywhere else so I'd appreciate any bits of
info any of you may have! Thanks in
advance!!! Greg NE
I see the seal kit for the on in the steering cylinder from New Holland is around $75.00, so I don't think that is too outrageous compared to the prices they are asking for other parts, but if you're looking for the cheapest way to go I would take the cylinder to a local hydraulics shop to see if they could source the seals for you.
Thanks for the reply! If I may ask what web site are you finding those prices? I
looked up Messicks and found the cylinder kit said like $200+ and the control valve
kit was $70 something. Right now all I need is for the control valve kit because it is
literally pouring oil out around the ball stud and the cylinder is looking pretty
good for now. I thought maybe someone here may have found another source for these
parts that bypassed New Holland. I know that sometimes you get what you pay for
but for something as simple as these seals maybe they were used in other
applications. Thanks
Provided you keep the end of the cylinder where the rod comes out clean you shouldn't need resealing. I just noticed yesterday that I have a little leak from the control end.
I rebuild the Bendix cylinders and have had good luck with them for the last 10 years.Let me know if I can help.Bob Hunter 580-603-0063 Waukomis, Okla.
Thanks, I may give you a call sometime. Right now my cylinder that is on the tractor is fine and I ended up having another control valve that doesn't leak but I may get it and my other cylinder fixed up sometime so I have good spares on hand.
