601 oil pan removal with 723 backhoe subframe
irishhill
New User
1961 Ford 621 (134 gas) with 723 backhoe, 703(I9-20I) loader. Subframe is a 19-302, channel with front mount bracket attached to front engine support and front axle. The front bracket blocks the front of the tractor oil pan (2 bolts). Anybody have any idea if it is possible (how to?) jack/support this to remove the front bracket with backhoe attached? Tractor is not running, so I cannot remove the backhoe.
If your tractor were in my barn, and if I understand what you're asking, I'd attach my cherry picker hoist to the top of the loader frame in front of the engine and unbolt the front of the loader; you might be able to drop the front of the loader enough to get to the pan, if not, detach the rear of the loader too.
