gregjo1948
Ford 1715--gear drive--Clutch is stuck so I can't get it in gear without shutting it down. If I start it in gear, I can't stop without popping it out of gear or shutting down the engine. I've tried jabbing the
brakes as I'm driving but didn't break the clutch free. Tried driving it into a tree and no luck there either. I'm going to try removing the starter to see if I can do anything in thru the hole. Thinking about
boring a hole thru the bellhousing to access the clutchplate. Any ideas on how to free this clutch, I'd appreciate your help. thanks, gregjo1948
