Commander 6000 advert
Brian-S
Someone tell me its a bad idea to buy this!
The ad reads:
Ford Commander 6000 (1965)
3.7 L Gas
Had it running last summer.
10 speed hydraulic transmission needs a tune up , tractor moves under its own power but can be finicky
Nice little project tractor for the right person
Have owners manual and service manual .
$1500.00 CAN ($1000 US)
(quoted from post at 10:31:19 04/06/22) I had one like that years ago, would have kept it if diesel. That thing was a pig on gas, so it went bye-bye.
Good point! With gas hitting 4.50 a gallon here its something to consider. That said this would be my acreage show tractor so fuel costs may not be so bad for me.
You're asking in the wrong place if you were hoping for a no. The left side rubber doesn't look to bad. Fuel line routing is interesting. Needs a battery so you are adding 10% instantly. If I could use it and have time to tinker with it, I would have a hard time saying no. But I also like the looks of the 6000.
(quoted from post at 11:00:28 04/06/22) If I could use it and have time to tinker with it, I would have a hard time saying no.
I guess thats a question - what are these like to tinker with? The motor should be no problem but what about that transmission: would I need a shop full of special tools?
(quoted from post at 12:06:18 04/06/22) That would be a fair price if it was a diesel. The gas part would be the deal-killer for me.
Im actually partial to gassers but Ive just learned that it doesnt have a 3pnt hitch: bit of deal breaker I think.
This post was edited by Brian-S on 04/06/2022 at 11:32 am.
I have most of the pieces for a 3-point assembly if you're interested. I was just getting ready to toss them in the scrap bin. Unless you live on the west coast, however, freight could make the idea prohibitively expensive.
Wow! I would have never thought Ford would have made what looks to be a true bareback (no provisions for a 3 point). Learned something today!
(quoted from post at 18:59:12 04/07/22) Gad models are fairly rare.
Vito
There was one that sold last weekend in Northern Ohio for around 3K, a gas 6000 (non-Commander model). And it looked fairly rough from the pictures.
I would have it on the trailer already. The SOS issue might not be anything a little tinkering couldn't fix. Being gas wouldn't matter for a toy. If it was a worker bee then it would need to be diesel. the rear tires look good.
I'm still thinking about this tractor.
Some questions:
1) Is the 3pnt system on the 6000 Commander the same as the 6000? I've found a couple of 6000s (non-Commander) in a local tractor salvage yard.
2) I've been looking at a lot of 6000 Commander photos and there seems to be variations in rear axle housing lengths. Or is the just an optical illusion caused by camera angles etc. The tractor I'm looking at has wider rear tires than I see on most yet the rims are set for a narrower track - how does that work?
3) I know the motor is not part of the chassis but can the transmission also be pulled without splitting the tractor?
Thanks
(quoted from post at 16:21:33 04/09/22)
Some questions:
Thanks
Brian, if you are planning a degree of restoration you should try for a 6000 using parts from a Commander if possible, due to the fact that a 6000 has far greater restored value than a Commander.
Why do you think a Commander has less value than an older one? There's not much difference between the two. Besides, the Commander is far better looking because it doesn't have that '58 Edsel-inspired front casting.
1) I believe they are the same. The parts book should be able to confirm that.
2) Same answer as above.
3) The image below should answer this question.
(quoted from post at 08:53:31 04/10/22) Why do you think a Commander has less value than an older one? There's not much difference between the two. Besides, the Commander is far better looking because it doesn't have that '58 Edsel-inspired front casting.
Bern you tell me why everybody seems to want one and I will tell you why the original ones appear to usually bring more money. Myself, I would like to have one because of the unusual factor even though to me they are equally ugly.
(quoted from post at 05:34:35 04/10/22)
(quoted from post at 09:53:31 04/10/22) Why do you think a Commander has less value than an older one? There's not much difference between the two. Besides, the Commander is far better looking because it doesn't have that '58 Edsel-inspired front casting.
(quoted from post at 11:30:26 04/10/22)
Interestingly, just this weekend an early 6000 diesel popped up locally. It's a non-runner, complete, but in significantly worse shape than the Commander I'm looking at. The asking price of CAN$5500 supports "showgrops" assertion that the earlier 6000s are considered more valuable. That said I'm with "bern" on the looks - the Commander is solid '60s kitsch while I find the original 6000s a bit over-done. I've never had any luck buying stuff like tractors for their investment value so it's important that I personally like the thing 'cause I'm likely going to be stuck with it.
This post was edited by Brian-S on 04/10/2022 at 12:50 pm.
(quoted from post at 09:59:27 04/10/22) 1) I believe they are the same. The parts book should be able to confirm that.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto122691.jpg>
Thanks Bern! That photo is a big help.
You bet. I have more like that to share if you'd like, as I went completely through my Commander a few years ago.
An interesting thing about the tractor I bought....the guy I bought it from parked it because he was convinced it had transmission issues. As
it turned out, the transmission was the only area on that tractor that I did NOT go through. It works perfect! Turns out the problem was in
the final drives.
I pulled the trans, looked at the oil as well as the input shaft, and took a peek inside the top cover and declared it to be fine. Having the
engine and trans out made it much easier for me to work on the rear axle and final drives.
That's interesting Bern. I'm usually not that lucky!
Another helpful photo - I do like the way they come apart.
This post was edited by Brian-S on 04/10/2022 at 09:26 pm.
