Ford 600 Carb-TSX593 vs 10A 355
RobWill
New User
I have a ford 600 and Im putting the engine all back together from a pile of parts I received from a 600 and 800 engine. I have 2 carbs, one TSX593 and one thats missing the brass tag that says 10A 355 on the bottom. They both look almost identical. Which would be the best for the 600? Theyre both in good shape just need to know which rebuild kit to buy. And if there would be any difference in performance. Brand new to these so all info is welcome.
If you have a local O'Reilly's auto parts tore they will have a kit that is likely to fit both carb. There Walker brand kits fit 2 sizes of the MS carbs
will both carbs work just fine on the 600 tho? Ive found kits for both just not sure which one will be best
The TSX593 is for the 800/900 series but if it will bolt on will work but may need to be adjusted a little on the lean side as to not to make it run rich. The 600 series used the tsx765 or500 580
