FOMOCO Farmer
We got the brake piston seals finished yesterday. Next will be replacing the front drive shaft seal in the transmission. The manual says to hold the output shaft back to the rear of the tractor. Is there a way
to do this other than just holding it back by hand? The seal was leaking so we decided to replace it while the hydraulic oil was drained. WE cleaned the inlet screen. It had some, not many, metal shavings in
it but I didn't think it was bad. While the rear wheel was off, I rewired the lift arm position sensor. Fingers crossed on that. One thing I did find was a 110 plug. It seems this tractor has a hydraulic oil
heater.
heater.
