New clutch rear tires arent moving ford 6610
ford401
After sliding tractor back together with new clutch, I put the tractor in gear and turn the crank(by hand) but the wheels dont move. It slid together normal, did not go hard. Was not forced. What am I missing! Clutch pedal is adjusted and seems to engage the throw out bearing like normal.
what happens when you rotate the rear wheels? By simple leverage of the large tires, it is much easier to move them and rotate the engine than to move the engine and rotate the wheels.
(quoted from post at 17:05:57 04/01/22)
Nope. If it did what were you thinking?
I was thinking that if it has dual power that you would have to spin the crank pretty darn fast to develop enough pressure for the dual power to engage.
