850 carburetor
itmeagain
major problem with this project finding a new carburetor for the tractor 850 ford .
carb was full of water and set for a long time so carb no good can't even remove top but these are the number I found
top OF BRASS ID # TSX- 708
then second one 62 N
number 3 EAF-9510-G
HELP !!!
EAF-9510-G is the correct Ford part number
for a 55/57 172 carburetor (800 or 900).
The original was likely TSX-593 (early) or
TSX-706 (later). TSX-708 marked 62 is
probably a correct Ford service
carburetor. I'm not sure why you would
have trouble finding a new replacement or
a rebuilt carb or a Zenith as all of those
are fairly common.
the last two i got was for 800 but came to fit 8n tractor this so upsetting
but i will order other one. but the other question i have 134 or 172 will the carb fit both tractor ?
ty
The carb for an 8N would be the TSX241A,B,or C and would not fit the 800 series. The 800 series is a 172 engine. This site list a number of rebuilt carb for your tractor
