kleine39kermit
On the Simms inline injector pump there are 2 Bango bolts. They are both 5/16. One is located near the top front of the pump which has lines connected to it that go to the injectors and the fuel tank.
The other one is located on the back of the pump and has a line connected that hss a loop in it and goes thru a bracket at the oil pan. This seems to be a vent for the oil resevoir for the pump cam shaft. Are these Banjo bolts identical? They have a very small hole in the sides but one seems plugged up. Any help would be appeciated.
