172 diesel. I have the tractor running again after installing the redone pump and injectors. It was blowing so much white smoke that I
couldn't let it run long enough to get up to operating temp. It also seemed to have a bit of a miss. Might be a few days before I can get it
outside to let it run long enough to warm up. I had attempted to time it before I removed the pump. Since it starts I'm guessing I'm fairly
close on the timing. What might be causing the white smoke? It wasn't this bad before. Is it possible that I'm a degree or two off time?
Is it possible to fine tune timing without pulling pump? If it matters the valves are only set to initial adjustment.
Thanks for any ideas what to look at next.
