3930 Steering Problem
Margo
I have a 1993 3930 that I am having steering problems with. Steering wheel turns but has a lot of play in it. Can turn steering wheel and takes several turns to start turning. Need advice on where to start. Has the hydrostatic steering.
This post was edited by Margo on 03/23/2022 at 03:54 pm.
Yes reservoir is full. In repacking the steering cylinder is it at bottom of steering wheel shaft? Thanks
No, 3930 has hydrostatic steering that uses a orbital motor under the steering wheel and a hydraulic cylinder at the front axle
On the tractors I have with that style steering the seals on the piston inside the cylinder have needed replaced
Installing a seal kit has fixed mine
