Mattoney01
Im back again seeking advice/guidance from the best of the best!!
67 Ford 2000 Diesel
**At the bottom of this post is a link to a YouTube video of the problem**
Ok guys. Many of you have helped me along with this tractor and I appreciate it!! I have had this issue and figured I would attack it when the time is right.
Im having a problem with the tractor white smoking and misfiring at higher RPM. I cant pin point an exact RPM as the tach isnt working. At idle and lower to mid range RPM the engine runs smooth but it does white smoke a bit but when you crank the rpm up it has a miss to it and white smokes a lot more. When your outside driving the tractor around at low to mid range RPM the white smoke is barely noticeable or not noticeable at all but definitely is visible at high RPMs (when the tractor begins to miss). Also, when you blip the throttle white smoke comes out pretty good. When the tractor is running inside even with the garage door open it has a pretty strong diesel smell, even to the fact your eyes will burn if you stay in there long enough. Outside obviously it isnt as noticeable. I would say its more smoke than steam but the video does show it fairly well so let me know what you think.
Here is what Ive done so far:
New fuel filters
Fresh diesel
New fuel injectors
Flushed, cleaned the oil bath air cleaner
Adjusted the valves
The previous owner stated the fuel injector was rebuilt last year. I was originally thinking maybe it was a poorly timed fuel pump but according to the dealer it wouldnt run at all if the pump wasnt timed correctly. They are leaning toward a head gasket problem. They advised to start the tractor while the engine is cold and look for bubbles in the coolant reservoir while it was running. I did that and had no bubbles. The reservoir is full and the level has stayed consistent. The crank case oil has good color. Its not milky indicating the coolant and oil is mixing. The temperature gauge does work and it doesnt overheat according to the gauge. The next warm day Im going to get the tractor back up to operating temperature and see if it still smokes at idle and lower/mid range RPM. Again, outside its hard to see and the last time I really used it I didnt notice. I know it still smokes and misses at higher rpms even when the engine is warm.
Lastly, no I havent done a compression test. Im thinking maybe Ive got low compression in a cylinder(s) due to wore out piston rings. Ive never done a compression test before so Ill have to research the proper way to do it. In a gasoline engine Im assuming you could remove the spark plug and test compression that way but not sure how you would in a diesel. Maybe remove the fuel injector? Ill research that.
Here is the link to the video on YouTube. Again, thank you for the help and information.
https://youtu.be/BXhmm9wBNGA
67 Ford 2000 Diesel
New fuel filters
Fresh diesel
New fuel injectors
Adjusted the valves
