Hello,
I have a 1969 Ford 3400 tractor that seems to be quite tired. The motor still runs good but the rear hydraulics are kind of sketchy, the transmission slips after about 10 minutes of hard work, Ive been driving around with just one power steering cylinder (which still works surprisingly well ) and now I split open one of the loader cylinder that tilts the bucket. I found a local business that is selling what they believe is a 1975 Ford 3400. His forklift mechanic had told him that the injector pump on this tractor is bad. Supposedly the motor was rebuilt back in 2005. I have a few concerns about the model. The model number is C4022C. According to springfieldbiz.com the third number 2 shows it is gas but it is definitely diesel like mine. On the date code (5K01B) it seems they are calling it a 1965 model but the seller believes it is a 1975. If it helps the color of the tractor is more like a caterpillar yellow rather than the more true yellow like my 1969 is. myfordtractors.com seems to confirm its the 1975 model because the serial number starts with C48.. If Im reading both of these website tables correctly they both indicate that the model is gas (2) which is not the case. Unfortunately I got the numbers off of the hood and not off the motor/trans cases.
If this is indeed a 1975 model will my 1969 fuel injector pump fit it and if I have to use the whole motor assembly will it fit? Any help would be appreciated here.
