Ford 3600 hydraulics/3 point hitch
lukejonesy
New User
If I move my lift control up, as soon as I
move it up the lift will go full up and as
soon as I lower my lift handle it goes full
down. I don't really have any control in-
between. Anybody know what it could be?
Could be in draft control. The little crooked lever on the right below the seat. If it's up push it down, if down pull it up. If that doesn't help it may be the pin in the linkage.
A 3600 should have two large handles on the quadrant. One is for draft control and will behave like you're describing. Try putting that one all of the way down and use the other one, which should be position control. If it only has a single handle on the quadrant then it is not a 3600, unless possibly it's a narrow orchard variant, as I think they still had the single handle on the quadrant and the small lever to switch between position and draft mode like the earlier tractors.
