mikewood869
I ended up getting a post (what I'm guessing) 1968 or 69 diesel Ford 3400, 8spd and pto (do not know if its live or not). Is there anyway of finding out what year this is beside the spot by the starter solenoid or hydraulic pump? The clevis for the clutch is a single hole (like on a 3 cylinder 4000), the clutch springs seem dead (the clutch pedal pops half up). At one point it seems like the motor might have been swapped (the air cleaner cover hole on the side of the hood, the engine is blue, but everything else with the oil pan is yellow), the injection pump has a lift pump on it (can't read the tag). The engine is stuck. The tag by the oil pan isn't stamped or has worn off. I'm going to take off the head tomorrow or the tractor will become parts.
