Has anyone used the clutch fork pin that you can buy on this website?
The purchased ones slide freely in both the clutch fork and shaft as well as the bracket on the end of the clutch shaft that goes through the bell housing.
I wonder if these should be a press fit but it seems like I need to peen it over to prevent slide out...how does a person do that while working in the bell housing and no real way to keep the pin from
wanting to come out as you try to tap the end without the end?
I may just buy a similar size pin with a hole in it and use a cotter pin? A person posted to try the Spirolok but I wonder what other techniques have been used to replace these pins.
thanks in advance, moday
