Ford 6610 fuel injector return T
mikewood869
Anyone know if you can get new fuel injector return T's new? I guess New Holland stopped selling them new. I was wonder if they could work from a different brand (maybe from a truck?)? It looks like the T's from the 3 cylinders might work (I pulled two off from our 3400 and they are a little short but they would work). The ones that I have are scratched. Could you use JB wield to fill the scratches in?
The return line isn't under a lot of pressure because the end back at the tank is open. Pressure requires a resistance to the flow and the only resistance is the internal diameter of the line and tee fitting. Unless the scratches are really substantial you should be able to use them as-is. If you do decide to use something to fill the scratches make sure that whatever you use is resistant to diesel fuel.
