Ford 7000 instrument panel/ turbo exhaust tempature
Does anyone know how to wire a new instrument panel for the 7000? I had the cluster panel working good with the new one installed but had to take it apart and forgot how it goes back together. Thanks!
Also should the exhaust temp coming off the turbo be 300 degrees farenheight? I took the muffler off and it cooled of about 10-15 degrees after that. Thanks!
Exhaust temp depends on engine load, and where the probe is. The probe usually is in the manifold before exhaust enters the turbine housing, but can be on the outlet too.
Exhaust temp at idle, no load is usually 250/300 degrees, under full load 1200/1300 degrees at rated speed.
Look at the color of the wires coming from the different senders and wire them to the gauges accordingly. Anything left will be the
dash lights, power supply and the ground.
