Ford 801 Block Heater
I want to install a freeze plug block heater in my HD Industrial Diesel. Just wondering what brand you guys were using?? It is 2 1/16 diameter. I was looking at one on line which was around $90.00. Im doing engine mounts in the spring and is a good opportunity to install a heater while the block is empty. Thanks for the help.
Im working on a Ford HD industrial tractor. The front of the engine is supported by two bushings. It doesnt have a bolster like the 801 series.
Zero Start and Kats are both good. Oreilly sells Zero Start Auto Zone carries Kats. No matter which you choose don't start the tractor with it plugged in.
