601 workmaster
FSA1953
What would be the easiest way to remove the retaining spring that holds the power steering pump filter in? Push down and turn? I've never seen a pump with this kind of hold down for the filter before. Thanks
The keeper should be slotted. Push down on the spring and turn the keeper till the slot lines up with the flat spot on the rod and pull it off.
