601 Workmaster loader
FSA1953
Try to find if they made a bigger bucket than the one that's on my machine it's about 36 wide.I was told it's that size to load coal wagons. I'd like to get a larger one if possible or possibly put on the quick attach so I couldn't swap to whatever I need.
601 is a series of tractor. There are a number of sub models of the 601 series. There is a good many loader which could be mounted on a 601 series Ford. Dearborn is one which is Ford's brand of loader or a Wagner brand loader. Hard for us to be able to help you help your self with out more info
I went back and looked at your pictures, that loader looks like a Ford 19-97 or 19-105 series 703 loader. The 19-97 had double-acting lift cylinders and the 19-105 single-acting. Anyway there were several different buckets available. The one I have is 5 ft wide and is probably the most common. Finding a used 5 ft bucket in good shape separate from the loader might be problematic though.
Here's a picture of my 5 ft bucket next to a TLB with a 7 ft bucket. Also a manual cover that shows the narrow bucket.
<img SRC =https://i.postimg.cc/LXQg632N/455-D-713resized.jpg>
<img SRC =https://i.postimg.cc/3NVScyPQ/703-Loader8-Na.jpg>
Here's the loader on my tractor. I was asking if they made a bigger bucket.
As mentioned you may have a difficult time finding one with the correct pin spacing but with some work you can replace that one. Watch online for a used one then just modify it to fit the width of your frame. You can cut the brackets off your existing bucket and reuse them.
There are probably bigger buckets for it but finding one might be like finding hens teeth
