Jamie in NC
I just got an 860 back in the fall and have been fixing some things on it. I now have it operational and have been using it. The PTO shaft has the adapter on it to use my modern PTO equipment like my fertilizer spreader and auger. I have used the auger and other than the lift height, it worked fine. I tried to hook up the fertilizer spreader and the PTO shaft would not go on because with the adapter, it stuck out too far and the PTO shaft on the spreader was pushed all the way in. I took the adapter off and it would work length wise, but its the wrong spline pattern. This spreader works well on my Jubilee and Massey and I dont really want to cut the shaft, so other than changing out the shaft in the tractor, is there another option like shorter adapter?
