601 Workmaster
FSA1953
Just picked the tractor up and trying to figure year and model out.
Top three numbers are:621
Bottom six numbers are:101010
Thanks for the help
621 is the model number. The 621 was a model in the 601 series. The middle digit specified which transmission, PTO and hydraulics options it had when it left the factory The 621 had a 4 speed transmission, no PTO and no 3 point lift hydraulics when it left the factory, but either or both could have been added later by a dealer or previous owner. 101010 is the serial number, and that is a 1969 serial number.
Yeah has no PTO or 3 point hitch. It was
used to load coal wagons. The bucket was
cut down to fit the wagons.
(quoted from post at 17:07:16 03/06/22) I think that should be 1959.
You are correct. My brain said 1959 but my fingers typed 1969. They tend to listen less and less to my brain as I get older.
Question do you know if there is a way
that I can install a 3 point hitch and Pto
drive? And where would I be able to get
the parts to do it? Thanks
(quoted from post at 19:18:22 03/07/22) Question do you know if there is a way
Parts for that are definitely no longer available new. You will need to scout around salvage yards for a tractor that has the parts that you need. The easiest thing would be to finds the rear half of a tractor that has a blown engine and then swap everything from the flywheel back onto your tractor. If your transmission already has the PTO output shaft protruding into the rear axle center housing then you might get away with just a rear axle swap. You would also need the hydraulic pump for the 3 point as well as the hydraulic manifold to go between the pump and the front of the transmission.
