Dieseltech
- Location
- Akron, Indiana
All Ford 3910s I've seen used the CAV DPA rotary injection pump that have three bolts through the drive gear that thread into the pump drive hub, NO nut used on DPA pumps
on Ford engines. There's a center Allen screw but it's NOT to be removed on engine. Remove the three bolts, and pump mount stud nuts then pull pump reward from the gear
case. When going back make sure the gear pin enters the hub slot for timing alignment.
