just found a old find of 800 ford
itmeagain
just found a 800 type ford tractor. it look like it has a Ganon box it missing the top link hyd, it plane box lever. but I going put reg link back to move it.
then come with a Wagner loader and better look then Dearborn and it 1 yd bucket. duel action rams so it going have down presser on loader it a gas type tractor 5
speed they said the point was burnt up but look at they might put 8 n point in because they told it was 8n ford but it don't have flat head motor. and pump is on
side of motor but the number that stamp on transmission tell what type it just has number of it . so what the value of this type of tractor
(quoted from post at 10:17:41 02/28/22)
This forum needs a like button.
Are you joking? The majority of folks on here still use the Classic View, and you want 21st century features?
Wow really? Classic view confuses the post order, I can't even imagine how.
Well consider my earlier reply a 19th century workaround. $600 to $4500 sounds right on target.
92506 is the serial number. There should be another number above that which is the model number. 800 is the series. The various models in the 800 series are the 820, 830, 840, 850 and 860. All of the tractor models in the 800 series were general purpose ag chassis tractors with a 172 ci gas engine. The different models had different options in terms of 3 point hydraulics, PTO and transmission.
