Jubilee 4cylinder gas
Crippledog
New User
I have a rebuild project I started pre heart attack, Pre flood disaster, pre knee replacement, and Im getting back to it been a few years but I lost the oil tube that runs from the rocker arm to the engine block. I really need that, is there anyone who has one for sale. Its a 1953 FORD JUBILEE 4 cylinder gas overhead valve engine. Thanks
looking at the CNH parts pages, you can see that the tube is the same for all of the 4 cyl OHV Fords. jubilee, 600s 800s 900s 801s etc. It appears to be NLA. the seal however is available from any dealer.
Not sure exactly which tube you need. However here are the part numbers for both from the 800 series. As Showcrop said they should be the same. Schematic also attached
#36 Long feed tube from push rod cover up - 86531523
#44 Short tube for oil drain back out of rocker arm tube - EAF6588E
Hopefully, someone here can help with a used one for you. Otherwise, hold on to your wallet IF you find a new one at a New Holland dealer. It looks like they would be in the $200 range
Crippledog.. I have what you need. I'll take pics of the tubes here shortly...... I think $30 + shipping outta cover it
(quoted from post at 07:40:12 03/01/22)
got side tracked
Send me $45 cash and that'll include the shipping.
This post was edited by nashranch on 03/02/2022 at 05:12 pm.
Im trying to Get back with Nash Ranch who posted me a picture of a Used Oil line I would like to purchase? Ph#918-671-3647
(quoted from post at 16:13:39 03/02/22)
Feeding Face now..will call in 15 minutes
Once you guys make connection, I would recommend you come back and edit your posts to delete names, addresses, and phone numbers.
