Got the top cover off the 6610 this morning and got everything redirected into the sump (after makeing quite a mess the first attempt...)
And it was holding just around 150 psi cold. Went ahead and tore everything apart I needed to in order to get the PTO brake band replaced
(20ft batwing and it getting shut off at full throttle do wonders for those little bands). I pulled both relief valves on the PTO valve
body out and cleaned the bores, put them back. I replaced the o-ring on the supply tube with a metric 3mm CS 12mm ID which is slightly
thicker than a -112 o ring the manual calls for. It sealed in perfectly, took away a lot of the slop, and the clip pin still clipped in
the groove. So anyone who comes across this, it seems to work very well upon first test.
Anyways, put everything back together, fired it up, ~160 psi at idle. I took a screw driver while it was running, and pushed in on the
washer stack for the relief valve, and the pressure increased. I went and grabbed a couple more washers and added them to the relief
valve, and now I have 180-185 psi cold (I know spec calls for 160-180). When idled up with cold oil, it climbs to ~225 psi. Is there
anything wrong with leaving it shimmed where it is? I feel like it's been said before it's better to have them shimmed to the high end if
you're working on them.
I still am having issues with the DP valve sticking. The old brake band was missing about half the lining, and the dual power discs on the
direct side were missing most of the brass lining, and I have found both of those things floating around after changing the oil and
filters. Would it be a good idea to run diesel in the rear end compartment for a few minutes stationary to try and flush all the debris
out? Or am I better off doing a short oil and filter change?
Hurst
Hurst
