Power steering cylinder seal kit
Tom Bond
Is the 309528 seal kit still available for the power steering cylinder with a 5/8" rod? Didn't see one on this site and only the 1/2" one looks available on others. Noticed a small drip on my 961 but the rod itself is actually perfectly clean and polished. No pitting at all so I think I may get away with just the 5 piece seal kit if I can find it. Thanks!
Assuming you need seal kit for 7/9 series PS cylinder.
Should be available from CNH.
Dean
Messicks says the kit or one of the components is NLA. Just like CNH. You might want to give them a call and verify what's available. Maybe you can source the NLA from someone else like Hercules Bulldog.
(quoted from post at 17:49:52 02/23/22) Tom- are you referring to the seals inside the seal gland? Bob
ust the rod end is leaking some. I believe it's just the wiper seals for the rod. The other end is dry with no leaks.
Available from CNH a few years ago.
Haven't bought one since I resealed the one on the tractor you bought from me earlier so don't know if still available.
If not, try to have your dealer locate one in stock at another dealer.
Dean
