Order Ford 801 Parts Online
Ford 801 Select-o-Speed
Pete in Ks.
05-04-1999 05:07:16
Neighbor has an 801 with Select-o-Speed trans. tractor runs ok but don't move so well. He would like to get it repaired. He was told that if a 5 speed trans could be found it would fit right in . I'm a little sceptical about the fit right in part. How tough to repair Select-o-Speed??
Tom aliotta
02-28-2004 15:12:42
 Re: Ford 801 Select-o-Speed in reply to Pete in Ks., 05-04-1999 05:07:16
I hope someone can help me. I have an 801 with sos and am unable to find someone who knows how to check or change the transmission fluid. My tractor slowed down today,6th gear was like 3rd. I believe its a transmission fluid problem. Can anyone help?
waldo
06-04-1999 09:11:41
have dead father's 801 with select-o-speed.
depressing to hear of ½ of resale because of
transmission: how hard is it to adjust
bands/clutches? how do i change trans fluid?
ANY reply appreciated!
regards,
jd
mailto:waldo@onenet.net
lacy
05-13-1999 07:28:25
need to know how it is messing up?
Bern
05-04-1999 12:36:40
An SOS trans can be a little intimidating to go through if you've never done it before, however, if you have a repair manual next to you and follow the instructions step by step, I wouldn't be afraid of it if I were you. As far as parts availability is concerned, about all you can get new any more nowadays is gaskets, seals, clutch plates, and a few small parts. However, used parts are plentiful in wrecking yards, so go for it! If you like, let me know what some of your symptoms are and I'll see if I can point you in the right direction. You might not need anything more than band adjustments!
Pete in Ks.
05-05-1999 04:55:32
 Re: Re: Ford 801 Select-o-Speed in reply to Bern, 05-04-1999 12:36:40
Thanks Bern, It may be a couple of weeks before we get into it but I will post on this site. With the help of you fine folks she may ride again.
Dave Mischler
05-04-1999 05:49:20
To swap a 5-speed in you will need to replace everything from the flywheel back to the differential housing. This will not be cheap,
especially if you go for the double clutch/live PTO setup.
Tractors with the Select-O-Speed transmission in working condition usually sell for half the price of an equivalent tractor with the 5 speed. That should tell you how fixable it is.
