841 power steering
hdbud55
New User
have water in power steering system. how do i go about flushing out the system,steering cylinders ,steering box and pump.
Crack the lines at the cylinders and run the engine. Keep steering it back and forth. Let it puke the oil out. Add new oil as needed. Continue till you get clean oil coming out.
To get any water out of the bottom of the steering box you will need to disassemble it at least enough to pull the sector gears out and suck it out somehow. Bottom of the box is seperate from the upper. Use 80W90 there.
