Ford 2910 fuel filter replacement
okgat
I have a Ford 2910. The fuel filter got clogged, so I need to replace it. I know they sell replacements of the type I need. But I was wondering if there was another way to replace it with a filter outside the tank. That way, it would be much easier to replace the filter in the future. Any thoughts would be appreciated.
Are you talking about the fuel filter that's mounted above the starter or the suction screen that's part of the fuel shutoff valve in the bottom of the tank?
How long have you had the tractor? How often does the screen get plugged? If a tank screen is plugging, you need to clean the tank while it is drained. If you have had the tractor for a while (several years?) and this is the first time you have pulled the screen out; I would say clean the tank, clean the screen and put it back in, don't add a filter outside. Then watch the fuel you are putting in. Fueling with cans and dirty funnels can get crap in a tank, if care and cleanliness are not watched. Metal tanks kept at low fuel levels are also more prone to rusting from condensation, keep it full as much as practical. If you are having to pull it out for cleaning often, then you probably need to look at replacing or lining the tank. Just my thoughts, others may have different thoughts.
Thank you for your excellent reply. I currently have my fuel tank out and using vinegar to clean it out. The fuel tank was very rusty. The fuel tank strainer was clogged also.
I have done all the things you said not to do. Tractor was left outside with the tank only partially filled with diesel fuel for years. The tractor is not run very often. Maybe 3-4 time a year. My plan after cleaning is?
1. Should I use or not use a sealer? I have heard bad things using sealers even when the tank is properly cleaned.
2. Since I don't use the tractor that often, will keeping it full of fuel cause problems? (I now have a place to store the tractor indoors).
Thank you again. Rick
(quoted from post at 17:49:21 01/27/22) Thank you for your excellent reply. I currently have my fuel tank out and using vinegar to clean it out. The fuel tank was very rusty. The fuel tank strainer was clogged also.
1. Use of a sealer. I too have heard good and bad reports. I have never used any sealer, so I won't say one way or the other on that.
2. Your usage makes it difficult. When you do run it, is it for a long enough time to get it up to temperature, the gearboxes and hydraulics as well as the engine? You should, if you don't. I think I would keep it near full of good quality "on road" diesel (not biodiesel). I would liberally treat it with a diesel conditioner like Power Service or Howes, and a light dose of a biocide (my suggesting these "snake oils" should get some other responses for you). Maybe even adding some 2-stroke oil, as well, which should help protect the tank by slowing rusting. Setting for any length of time seems to bring on sticking parts in pumps these days so frequent running will help. I don't know where you are located but around here inside storage, if not climate controlled, will still allow condensation to form. The biggest reason for inside storage here is it keeps the direct weather off equipment. when the temps swing from well below freezing to 40 or above in less than 24 hours there will be frost and water droplets on equipment parked inside unheated storage. Just my thoughts, others may differ as they will have methods that work for them.
If you decide to use a sealer, get a complete kit, which includes a pre-treating solution, usually containing muriatic acid, which is a bit stronger than vinegar. Be sure to follow the instructions to the letter.
