Company Logo Shop Now
Order Ford 800 Parts Online
Re: Ford 800 Tractor Hydraulics
Bern
05-03-1999 16:43:39
Question. Will implement settle all the way to the ground when you shut the engine off? If so, you have an internal leak. Possibly a worn control valve, leaking unload valve plug, lift piston seals, etc. A sticking unload valve will make the system dead, not bounce around like yours is. Try draining some of the oil out of the reservoir, remove access cover (one with dipstick), and look inside with a mirror and flashlight while your 3 point is settling down (engine off). By doing this you might be able to see exactly where your leak is. Could also be a lift cylinder safety valve, but these rarely give trouble.
Matt
05-04-1999 05:30:20
 Re: Re: Ford 800 Tractor Hydraulics in reply to Bern, 05-03-1999 16:43:39
Thanks. If I remember correctly, the implement settled to the ground when I shut the engine off, but I will check it again. I did replace the lift piston O-ring and backup seal, however I did not measure the piston O.D. or lift cylinder I.D. to check for clearance. The piston fit was fairly snug when I installed into lift cylinder so I don't think fluid is leaking past piston. However, I plan to check for internal leakage as you suggested and then go from there. Thanks again.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
