Jeff Hamilton
I've had the '52 8N for 6 years and just got a 1955 860 . My question is with regard to the steering. The 8N steers with ease, it's not power steering, but on a scale of 1-10 with 10 being very hard steering, I'd rate the 8N steering a 3 to 4. However, the 860 steering is more like a 7-8 (also, not power). If you're performing a slow maneuver with the 860 it's a two handed effort (direction does not matter). No loaders involved. Both tractors have 6X16 3 rib front tires, although the 8N fronts are new and, with the 860 front tires, the center rib is a lot taller than the side ribs. The 8n rear tires are empty, but the 860 rears are loaded. In both cases, nothing hanging on the 3-point. Oh, I almost forgot, the 8N is a side mount, 12V and I have all the important manuals for both tractors! So, is it typical that the 860 steers so much harder or should I look for something to fix? thanks, Jeff
