so i may be clogging up the board here about this backhoe i got from my dad. the notes in the service manual's he has (vol-1, and vol 2) indicate that there is no actual serial number plate but the place he bought it at years ago, had work done on it at a place called APCO in las vegas, and they had it listed as a FORD 555A with a SN #C591951
does that seem to make sense to the ford experts?
so i just took it to the ranch and the first day it ran pretty good, the second day i started doing a lot pushing over bushes with the loader and was using the steering a lot,, toward the end of the day, it was starting to get really hard to steer,, so i checked the power steering pump (gear driven on the driver side of engine below alternator) it was low on fluid,, quite a leak going on,, looks like it is coming out of the cannister possibly,, but also maybe the hoses in between cyclinder under the tractor that turn the wheels. anyway, i add fluid, raise up the front the wheels with bucket and turn them all the way back and forth for a few times, so next morning,, the steering is better, but still hard, and i am doing some hard work with it again,, by the end of the day, or after a 4 ish hours,, it was almost impossible to steer, really hard to turn wheel,, and when i did, the tires didn't even respond hardly,, takes like 3 full turns to get a little turn,,, seems to do better with a few rpms but not much. so with it running, i can see a little fluid in the power steering pump moving around a bit,, kind of inside the perforations inside it.
so my questions,, is any one a darn good mechanic on these ford 555's? i am going to order a seal kite and filter for the cannister,, hopefully the serial number i have is correct. how hard is it to replace the hoses down below? would sure be intersted in talking someone who has recently done this, my email is [email protected]
also,, what size is the long alternator bolt,, 3/8", 7/16"
This post was edited by rockwind1 on 01/23/2022 at 06:03 am.
