Hi everyone, I sure could use some help, sorry this is a
lengthy post, my 1975 Ford 2000 3 cylinder dual clutch gas
engine needed a clutch job, when I split the tractor the clutch
disc seemed to be backwards,the long side was to the front
instead of towards the transmission, I had the flywheel turned
bought a rebuilt clutch kit , replaced everything including input
, output shaft seals, freeze plugs, main seal etc, I put
everything back together with the long side of the clutch plate
toward the transmission as manual showed, now after
adjusting clutch linkage the clutch is not working, tractor
wants to move when trying to start, any ideas what I could
have done wrong? Thanks in advance
