Needing to clean out the Hyd. Reservoir I finally talked myself into removing the cover (my first). Interesting device. Plan to check adjustments and take a look at the piston to see if original or not.
Some discoveries are a not fully tightened bolt on the Diff pinion cover. And what I guess folks mention as the Cam Follower pin appears to still be round. Wondering what the yellow paint signifies.
Also when I loosened the Large Acorn nut it didn't come off but is firm on the threaded portion of the bypass valve.
Should I apply a little force to see if it comes loose ?
The bypass valve left a good impression on the rubber seal.
