Hi All,
I recently purchased what I believe to be a 1964 Ford 4000 4 clyde diesel (the SN is basically uninterpretable, but based on my research, it's definitely pre 1965). I'm having problems with the rear hydraulics. They seem to be fixed in the up position regardless of what I do with the position lever. The only way to drop lower the lift arms is to use the selector block to release the pressure.
I've rebuilt the pump since it started leaking and have hydraulic pressure. It will lift the bush hog I have on back, but I can really only control the direction with the selector valve and not the position lever which is less than ideal. I've pulled the selector valve and noticed a missing oring on the plunger which I plan on replacing.
I apologize if this has been covered in a previous post, but I haven't been able to locate anything covering this particular issue. Does anyone have any insights on what might be the culprit here, and what might be involved to fix this problem. It would be great to have some feedback before I crack the top lod and start exploring.
Thanks,
AG
Thanks,
AG
