I have 2 Ford tractors. A 1965 4000 RC and a 1972 3500 industrial. Both are gas. 4000 4 spd w/ hi/lol and 3500 is 4 spd w/ F/R converter. My question is if I were to change out the 3500 transmission and rear end and replace it w/ the 4000 transmission and rear end , will it work ? Plan on using the 3500 for raking and teddering hay. Ground is too rolling for the converter transmission. My grandsons help me out with these jobs and I don't want them or me to be injured due to getting bounced off a runaway tractor. The 3500 has no PTO shaft and I have replaced the clutch, pressure plate, t/o bearing on the 4000. It has hydraulic independent PTO and double hydraulic valve as well.
If it will work how big of a job is that going to be ?
