5000 Ford Power steering
JPK
Rebuilt power assist cylinder with new o rings and piston ring.Installed back in tractor and it steered the best since i owned the tractor but has a leak. My valve housing is a two piece housing. It has a gasket o ring that goes between the two parts were the spool enters. where does item 21 o ring go. When i tore it down i did not find item 21. Does it go on the valve spool or was it used in a different valve housing. Piston rod and valve spool measured to spec. I am using Messick parts list.
