Rear rims 1963 ford 2000
jeffs667
New User
I'll try to explain as best I can. My rear outer rims are not six loop. There are clamps holding the inner and outer together. All I can find are six loop outers. Will my inner rim be usable with a six loop
outer? thanks
4 clamps? Power adjust wheels? 6 loop will not work on those. They say pictures are worth aq thousand words.
This post was edited by Larry NCKS on 10/23/2021 at 05:48 pm.
(quoted from post at 16:42:15 10/23/21) I'll try to explain as best I can. My rear outer rims are not six loop. There are clamps holding the inner and outer together. All I can find are six loop outers. Will my inner rim be usable with a six loop
outer? thanks
No, the six loop rims will not work with your centers. Your 2000 must be a LCG model.
So now the question, what would you do? One rim is holding air but is so rusted I won't be able to put new tire on. Both centers look good. I would lean towards easiest and available, not necessarily cheapest.
Six loop rims are generic. The correct 28 six loop rim for your 2000 is 10 wide as properly measured, 11 overall width. Correct tire size is 12.4X28.
I would buy used six loop, 28 wheel centers from an individual or a salvage yard. Should not cost much. Can often find free if patient. New ones will be very expensive.
Dean
