On Snap, never did get around the replacing that fan belt...
stupid is as stupid does.
Moving the massive snow piles with the "66 4500 TLB on Saturday and it starts tat tat tat. "What"s that, that don"t sound good." Shut it down, take a look. Ancient fan belt I should of, could of changed a shredded mess.
Great, Snow is piled 4-5 feet deep in front of bay door to garage that fits the tractor. Been rained on and frozen too. Parked it, covered with tarp. The permafrost ice sheet under the tractor looks so lovely to work on.
Snap, I do not even know the exact belt it is as the 4500 has a alternator conversion gerry rigged on it.
Order 5 ft of v-link belt in the hop ei can run it long enough to move the snow from in front of the bay I need to use.
Pete
That is pretty much the same question that I have been pondering... I have a Jubilee with FEL and V-link belt that looks pretty worn.
Question is- Do V-link belts hold up the same a regular V belts? It looks like mine seems to stretch over time.
What is anyone else's opinions?
Greg
I've run a few of them, with good results. Especially handy when putting a regular belt in means a lot of disassembly just to get at it. Any belt will stretch some with age and use.
Will let you know how it works next weekend. Belt should come this week but i will be away on biz till Friday.
More snow while i am away too.
Pete
V-link belt arrived. Going to hit 30+ tomorrow, will get it on see if it "works".
Pete
It worked!
Ran it for 5 minutes. Shut it down and snugged belt a wee bit tighter. Then ran it hard moving frozen snow mountains.
Looks snazzy too!
Pete
Greg,
Amazon. Costs about 3 times what a standard belt costs. But it was worth it.
I used some old telephone wire to sank it around under the crank pulley. Never even had to get on ground.
I tried to post a video link but could not get it to work.
Pete
Pete- Is that a V-belt or flat 1/2 inch belt? Seems all I can find on Amazon is flat belts...or does it matter? thanks.
Greg
The individual links are flat, but when you link them together the tabs that go through to the inside are shaped with a "v" profile so they go down into the "v" of the pulley and work like a v-belt.
Just wanted ALL to know this v-link belt is still working on Bertha the 4500!
Pete
(quoted from post at 19:46:00 03/01/14) It worked!
Looks snazzy too!
Pete
Bertha is still happy using this v-link belt!
Was thinking the other day i should buy a spare one.
Pete
(quoted from post at 10:11:01 10/23/21) Just wanted ALL to know this v-link belt is still working on Bertha the 4500!
Pete
Looks snazzy too!
Pete
/quote]
Wow, that's the craziest belt I've ever seen! I'm honestly surprised it works...and almost 10 years later too. I'm with you though, would make replacing the belt much faster.
Have the same set up on my 4500. It's been working well for 4 years. Tractor is ugly with huge amounts of blow-by, but starts and runs and works for what I use it for.
