My cousin has this 65 Ford backhoe that only has the loader on it as someone has removed the back hoe from it. It has sat quite some time as he uses it very little because of it's size. He tried to use it a couple weeks ago and the clutch is frozen. He can start it in neutral but can't shift it after starting but he can put it in gear when off. We tried to start it in gear today but it pulled the battery way down trying to start it as it moved in gear. Any ideas of how to free up the clutch without breaking it apart as that looks like a very BIG job with all that big loader/backhoe framework on it? He has put a big rock on the clutch pedal to hold it down but didn't help. He also pulled the starter and tried to spray brake cleaner into the flywheel but I doubt he got it in there very good.
