Diggerdon
I am fixing a Ford 821 172 Gas (1961). It came without a air cleaner. Ford shows part # 311095 but I can't find one for a gas. Does anyone
have a photo of the air cleaner, on their 801 ? I can find cleaners for diesels but not gas. I would like to see one up close.
Here's a couple. I think the air cleaner on my 960 and 950 are the same as the 801...... would have to go look.
Ahhh...I didn't walk down to the barn to check before I posted. But I do see that now! Oh well. Maybe the pictures will help?
Try this link. This is the schematic for your part number on the New Holland site. It should give you an idea for what it looks like. It also shows 311093 & 311094 as alternate numbers to 311095. Maybe something will pop up for you if you search the other numbers. Good luck
https://www.mycnhistore.com/us/en/newhollandag/tractors/utility/naba87400industrial/4-cyl-ag-tractor-industrial/fuel-system/gasoline-air-cleaner-related-parts-58/cn/CD57C5C9-B8BF-E111-9FCE-005056875BD6?modelCode=9CEE724F-E6BE-E111-9FCE-005056875BD6&isSnFilterEnabled=fal
Thanks to everyone for the info. Looks like the same cleaner is used on the diesel. Can someone measure the gas (top to bottom) to check against the diesel ? If someone knows for sure if they are the same , let me know .
