Early in the season she started right after after the winter. Next time I go to start it, seems the battery was dead. So I charged it up, eventually replaced it and still no start.
I just replaced the starter solenoid, checked all the switches and she only starts when I short the solenoid posts, and immediately dies when I remove that connection. I am getting 12V to the ON/OFF toggle, and it seems to work as designed.
The only thing that I did not test is the foot ignition switch, which I can't seem to get off, but I am going to "short" that out today and see if it will start on her own.
What should I look at next, ignition coil? Any ideas?
Thank you in advance.
