My rebuild project is finally making some progress, I had to wait quite a while to get the block and head into the machine shop ( they are very busy).
But all machine work is done now and it's coming home for assembly, only surprise was a cracked crank which is now replaced...ouch!
I'll be installing a Reliance engine kit when I get it home, Erik from Erik's machinery rebuilt the injectors and pump and painting is progressing well.
New tires for the front are mounted and ready, new used tires for the rear are on the tractor.
I gained 4 " of clearance with the 14.9 x 28's on the rear , the ones that were on it were only 26" diameter.
Thanks to Hobo, Pomster, and a few others for info and part numbers in a couple of threads for shaft seals and and Quattro ring dash numbers!
Before and after grit blasting...
