ford 4500 tractor backhoe
larry zielkowski
started the tractor this morning wouldn't go into gear the clutch is not working. I checked the linkage it all moves freely anyone have any ideas that might work short of separating the tractor thanks
clutch worked last time I used it about 2 weeks ago now it goes up and down with no resistance
(quoted from post at 00:41:32 10/16/21) I think it's a 3 speed high and low
I dont have a solution for your problem. I need some info. I see bracket that holds steel line in pic. I need demsions for it and the one thats kinda under step that holds 3 lines.Thanks in advance
