Need help with finding out what model I have
Careyaikman
New User
Trying to rebuild this Ford front loader tractor and can't find out what model and year it is. Engine are says C5Nn6015 no model number on plate. Would really appreciate any help you could give!
Any letters off to the right of the C5NN6015?
After about 10 posts you will be allowed to post pictures, so please post pictures of the tractor when you can.
C5NN6015T1 is the engine block code.
Seems to be for a 201 diesel. C5 means it
was first designed in the 60s, 5 means
1965, NN means that it was designed for
tractor use and 6015 is the number for an
engine block, T the revision. Anyway if
there isn't model number on the sheet
metal and you can't find a plate or foil
sticker then find the starter on the right
side of the tractor and to the rear of
that there should be a flat area where the
model number, serial number, and date code
are stamped. Those are the codes that
will identify the tractor. Post those.
On flange to rear of starter the is 3 lines of digits. One will start with CXXXXXXX , another will have digits and letters like, 6B21 , and another like, D5011F. Them numbers posted just says engine block
first used in 1965.
As Andy said, C5NN6015T1 is a 201 cubic inch diesel engine block and the casting was designed in 1965, so it is likely a model in the 1965-1975 4000 series. Pretty much all of the models in the 4000 series could have had a loader added to them. Look on the right side of the tractor, just above, and rearward from, the starter and find the two large bolt holes. The loader frame may be bolted to one or both of the holes. Just above those 2 holes is a flat spot in the casting the faces upwards. There should be some numbers stamped into that flat spot.. If you can find them, post them back here and we can probably figure out what it is.
The block was originally a 175 cubic inch diesel block (3000).
ND197883H316 makes: 3000 diesel August 31 1966.
What makes it a 4000 (201 cubic inch) block?
A Google search on C5NN6015T1 returns only a few hits and they are all claiming that casting code is a 201 ci diesel. I didn't think to realize that ND197883H316 was the engine s/n. That would indicate that it was made for a 3000 series tractor and is a diesel, and the 3000 series diesels were 175 ci, so there is conflicting information.
Still trying to find different numbers. And trying to post pics. I'm trying to find a diagram of the hydraulic lines. They had been removed and I can't figure out where some go.
