Re: Any advice on which Forum for newer 445A Ford?
JoeM(GA)
The grommets on my 345 C were slit at each tube, not sure if it was factory or previous owners
Ah, that's how they do it. Good to know. What do you guys use to degrease? I've been using cheap oven cleaner from the 99 cent stores and a pressure washer. Actually a pressure washer first to knock off the big chunks and then coat what's left with the oven cleaner and then again with the pressure washer. Rinse and repeat.
Tom
careful with the oven cleaner, most will remove paint and can damage things like radiators and coolers
I use "Purple Power" mixed strong, sprayed on with a 1 gallon sprayer , re-wetting every 15 minutes or so, then wash with the pressure washer(small electric 1800psi)running off the hot water outlet in my shop sink. Does pretty good.
You are replying to an old post in Modern
view. None of us who use Classic view are
going to know what you are talking about
(the majority of us here) unless we click
over to Modern - which ain't likely.
I suggest you learn how Modern and Classic
work together - they actually don't - and
either start a new post or give us a link
to the original one.
Thanks
