Can I remove this lever?
root
This is the shift lever for a 69 Ford 4000. It rotates real bad. I noticed this pin is gone. I was going to try and weld it back if I can get it out. Looks like I can drill the ring out and it should come out. Any thoughts?
[/list]
(quoted from post at 17:54:03 10/07/21) Remove knob and snap ring on top,comes out bottom . Has dowel pin in shifter.
Yep that worked. Thanks.
Do these take 134d?
